Orderd Catch Can
Old 01-09-2006, 09:34 PM
xtremeskier's Avatar
Ok, well i ordered a catch can off eBay for like $40. Now, i've searched and found two different ways of hooking this up, which is confusing me. sad.gif
Do i hook it up in between the hose that goes from the PCV to the intake manifold?
OR
Do i hook it up in between the hose that goes from the crankcase vent to the intake elbow (before throttle body)??
Old 01-09-2006, 09:35 PM
leave the pcv
you connect it to the crankcase vent
Old 01-09-2006, 09:45 PM
Take some pics and stuff when you install it. Which one did you order?
Old 01-09-2006, 09:47 PM
http://cgi.ebay.ca/OIL-CATCH-RESERVOIR-TAN...1QQcmdZViewItem
How does it catch oil then? Doesn't the blowby go through the PCV to the IM?
I'm having a hard time understanding this 02.gif.
Old 01-09-2006, 10:46 PM
col96fx's Avatar
Vehicle: Hyosung GT650
Low pressure blow-by goes through the pcv, and high pressure blow-by goes through the other line to the elbow. I have mine with both lines from the engine cover going to the can, and the can venting back to the elbow. To do this I removed the pcv and blocked the fitting on the im.
Old 01-09-2006, 11:02 PM
Ok, i see now.smile.gif I made two pictures. A+ quality, lol. Let's say i didn't want to route both hoses to the catch can. Which would be the better option?, Picture #1, or Picture #2.
Picture #1
Picture #2
(Assuming i leave the PCV valve in)
-Edit- Wow, those are smaller than i expected!
Old 01-09-2006, 11:14 PM
Hook it up either way mate... From what non-boosted & non-autoX people say a catch-can seems to do very little anyway.
Old 01-09-2006, 11:21 PM
Mostly just for piece of mind.
Old 01-09-2006, 11:48 PM
cbehage's Avatar
I want this one. It Is C/F.
I had the plasic campbell one from walmart. Mine used to get FULL of gass/oil mix.
I took if just from the crankcase vent.
Old 01-10-2006, 12:08 AM
That looks pretty nice! Ok so i see most people do it from the crankcase vent (breather hose), to the intake elbow (before throttle body).
Not from the PCV valve to the intake manifold (after throttle body). Finally, all cleared up. fing02.gif
I'll post some pics when i get it all setup.
