Omfg Car Wont Do A Thing
#21
ok got the car running, read codes ckp sensor, now it does start every now and then, with no push so I am guessing the sensor is loose, how do I get to the sensor where is it and how do I check it. The guy stated it costs $72 for the sensor if its bad then I am going to get a new one but if its just loose then I am in luck.
#22
![](https://www.hyundaiaftermarket.org/forum/images/ranks/admin.png)
Ok so it runs in line with the belts what section is it on in webtech so I can look at how they access it to remove it and install it. Do I have to be under the car or from the top?
#26
THose pictures aren't our engine BTW.
That sensor has been talked about to death here on this site.
Hell, I even had major problems with it before.
BTW, that's the CEL that ABQElantra got on the 1997 tib that I told you about.
The crank position sensor is on the front of the engine, low, on the right side facing the engine from the front bumper.
#28
<div class='quotetop'>QUOTE </div><div class='quotemain'>The crank position sensor is on the front of the engine, low, on the right side facing the engine from the front bumper.</div>
Top of the car of course, you wouldn't be in front of the bumper if you were under it.
