Oil Pressure Gauge
Old 05-15-2005, 11:38 AM
  #21
Pyro's Avatar
thanx for the pic
so this one?
Old 05-15-2005, 02:05 PM
  #22
right-o
Old 05-15-2005, 03:02 PM
  #23
Pyro's Avatar
awesome thanx for the help
Old 05-16-2005, 06:43 PM
  #24
silvertibbs's Avatar
Vehicle: 2004 Acura TL
SO other than that there is no other spot in the engine to grab an oil pressure reading from??? What about somewhere higher??
Old 05-16-2005, 07:18 PM
  #25
The_Alpha_Male's Avatar
nice.... i'll need this info too in a bit...
Old 05-16-2005, 08:54 PM
  #26
<div class='quotetop'>QUOTE (silvertibbs @ May 16 2005, 07:43 PM)</div><div class='quotemain'>SO other than that there is no other spot in the engine to grab an oil pressure reading from??? What about somewhere higher??
Why would you want to go someplace higher on the engine? There is a restrictor in the head that lowers the oilpressure some, so you will not get a proper reading from anywhere but on the block. As that is where the factory decided to get the oil pressure readings from, it is probably the best place.
Old 05-22-2005, 02:09 PM
  #27
Good point.
I was just thinking more in terms of feeding oil to the head. If there is a problem with oil pressure I was thinking that is where you'd want to catch it. That's all.
Old 07-12-2005, 05:41 PM
  #28
TiburonWao's Avatar
<div class='quotetop'>QUOTE (Mad-Machine @ May 17 2005, 02:54 AM)</div><div class='quotemain'>Why would you want to go someplace higher on the engine? There is a restrictor in the head that lowers the oilpressure some, so you will not get a proper reading from anywhere but on the block. As that is where the factory decided to get the oil pressure readings from, it is probably the best place.
You are totally right.... Also I take the oil feed line of the Turbo from here....
Old 07-13-2005, 03:04 AM
  #29
<div class='quotetop'>QUOTE (Mad-Machine @ May 16 2005, 06:54 PM)</div><div class='quotemain'>Why would you want to go someplace higher on the engine? There is a restrictor in the head that lowers the oilpressure some, so you will not get a proper reading from anywhere but on the block. As that is where the factory decided to get the oil pressure readings from, it is probably the best place.
i'm with arthur here. if it's there on the factory set up.... there's a reason for that. plus you shouldn't have to alter anything.
stock isn't always bad. hah
Old 07-21-2006, 06:44 AM
  #30
pbdude23's Avatar
there may be an ounce of oil that leaks out as long as the engine is not running. I just put mine in, there will be little to no oil leakage
pictures on it installed the copper line runs stright to the t, mine is a mechanical
