Obd2 While Cranking?
Hi,
My car is not starting, and I'm trying to determine the cause. It seems I have no spark; the ECU doesn't send the alternating ground to the coils (test light doesn't flash in coils connector while cranking).
The 2 most probable causes are the crank sensor, and the ECU itself. I was trying to see if you could see the engine's RPM while cranking using OBD2, but the connection drops when cranking. I'm not 100% sure, but I seems to remember doing that procedure in the past, so I'm wondering if it's normal. If you have an OBD2 scanner, could you check that please? Try to see if you can see RPM while cranking. Thanks!
It seems that losing the OBD2 connection while cranking is normal.
My problem was indeed the crank sensor (confirmed by trying it on another car) and the coil connection was flaky at best; the car is now starting like a charm wink1.gif
