O2 Sensor Bypass?
I know this has been covered before, because I remember it. I can't seem to find it through searching though. I have the OBX Racing headers without the o2 sensor hookup.. I've just put up with it for a while, but it's running really rich. There was this thing someone found on eBay that will just disregard the missing o2 sensor and give the computer an OK read that will fix this.. I don't know what to search for to find it though lol.. any help?
Guest
Posts: n/a
to remove the error from the computer you can use an OBD-II scanner that allows you to program the computer. Most mechanics have a professional one that allows them to erase most codes, even Airbag ones. But without eliminating the problem that causes it, the light may come back.
Well, I've had them clear it off once or twice but it always ends up coming back on.. I didn't know if that thing you can get off eBay would totally remove the problem or not. It seems like it should, but I just don't know what to search for to find it, lol.
look up o2 simulator on ebay.
pre-warning, pretty often, they dont work. my car being one of them, hell, the damn thing is still installed to this day, still have a code though. even with a brand new o2 sensor.
Umm if you are talking about bypassing your primary O2 sensor (the one that would have been in the stock exhaust manifold) you can't do that. For your car to run properly you have to use the primary O2 sensor so that your ECU knows how much fuel to add compared to the MAF sensor readings. You would be running hella rich because the ECU goes into safe mode due to no reading being present. The ECU does this so that you don't end up running a lean air/fuel mixture and hurting something. You will need an O2 bung welded into your header somewhere for your car to run properly.
If your talking about the second o2 sensor, you can use a simulator, Ive done it with great success, actually i just passed inspection with it a few weeks back
but not having your second 02 sensor wont affect performance, youll just get the CEL, so im assuming your talking about the first o2 sensor, which you cant simulate.
<div class='quotetop'>QUOTE (Alex01tib @ Aug 23 2006, 09:55 PM) <{POST_SNAPBACK}></div><div class='quotemain'>If your talking about the second o2 sensor, you can use a simulator, Ive done it with great success</div>
as i posted earlier, it SOMETIMES works, but not allways, so its a chance sort of thing, mine still doesnt work, even with a brand new o2 sensor installed. im gonna try replacing the damn ecu soons because even my primary reads bad, and ive gone through 3 new ones in the last few months, and the code will never clear no matter how many times i have it erased. it comes back after like 2 starts.
