Noise When Turning
Hey
I have a 99FX, i started notice loud hummm noise coming from the front of the car, only when im truning at a slow pase. I checked the power steering fluid and its fine, check for an sort of leak.
Everything seems fine!
Wheel bearings are the usual cause of unusual sounds from the corners of the vehical. Could be wheel rubbing or brakes have you checked for debris?
Vehicle: Elantra HD / 2007
if it's at low speed it can be CV joint.
If you turn (wheel all the way right/left) and drive slowly forward then backward, do you have CLICK-CLICK (somshing like metal grinding sound)?
Could be wheel bearing, CV Joint, or ball joint. If it is only when cornering it is more than likely not the wheel bearings as you would usually hear grinding when turning as well as regular driving.
CV joints make a distinctive "clickclickclick" noise when you turn. Ball Joint would ONLY make noise (if it makes noise) when you are turning the wheel, not when making a steady turn. I am betting on a wheel bearing.
I replaced the wheel bearing on both side, 4months ago.
And im still having the problem, it only happens when im turning sharp at a slow pase
Its a loud hummmmmming sound, almost like a horn or something. Its really anoying.
It Could be the brake pads rubbing agianst the rotor
