Need Serious Help
Old 06-27-2009, 05:22 PM
gen1xslugger's Avatar
need to fix asap, going out of town tomorrow
problem: Car got broken into, dealing with replacing and installing everything. the body shop replaced all the center console plastics and i still have all my wires hanging out from the stolen stereo. last night for some reason my footwell neons, guage lights, and the lights that lite up the p, r, n, d, d1,d2 by the shifter are all not working. Today i installed my amp and stereo.. and neither are working (i assumed since non of the other electronics are working). what confuses me, is the power light on the amp wont even light up...
i have checked my fuses, and all are fine... i have NO idea what to do... please guys open for any suggestion...
Old 06-27-2009, 06:55 PM
You checked both fuse boxes? Other than that, a cut wire.
Old 06-27-2009, 07:39 PM
frozen's Avatar
Vehicle: 2001 Tiburon
Do the lights for the A/C controls work? Also check if both taillights work. Sounds like fuses. Do you have a test light/multimeter?
Old 06-27-2009, 07:58 PM
no multimeter, ac contorls work, break lights work... i didnt check the engine bay fuse box.. i just dont get how the gauge would go, the lights by the shifter, my footwell neons... no power to HU (even though i may have installed wrong.. now way to find out), and no power to my amp.
Old 06-27-2009, 08:25 PM
frozen's Avatar
The A/C control LIGHTS work?
Do both tail lights come on when you turn the headlights on?
edit: Do the power window buttons light up? How about the other switches (fog lamp switch, hazards switch), the cigarette lighter light, do all of these lights come on when you turn the headlights on?
Old 06-27-2009, 08:26 PM
ok i checked again, you are right... front left headlight, back left tailight, no ac control lights, no floor leds, no stereo, no gauges.
i cant check..no multimeter... what fuse will needa b replaced?
Old 06-27-2009, 08:58 PM
frozen's Avatar
Replace the left taillamp fuse, 10 amp in the engine compartment fusebox. The left headlight should be on with the right one, it's probably just a coincidence and you have a burnt bulb.
edit: Replace fuse 14 in the dash fusebox, that is the fuse that powers the HU.
Old 06-27-2009, 09:00 PM
the bulb was just replaced...weird... its not the headlight i think its the headlamp....
you think changing fuse 14 and amp 10 will fix the gauges, hu, tailight, floor neons, ac lights, and the amp....?
Old 06-27-2009, 09:46 PM
Try replacing each fuse, one at a time under the dash, I've had 2 so far go bad that looked 100% OK, but were still bad.
Old 06-28-2009, 12:06 AM
frozen's Avatar
All the illuminations are controlled by that, so yes. Once that is working then you can worry about the HU, but replace fuse 14 (audio fuse).
Just to elaborate on what redz said, don't rely on your eyes when it comes to electrical. If you can't test with a meter or test light, replace the fuses with known good ones. I don't know how many cases of beer I've gotten because people said their fuses 'looked' good.
