Need Help! Fuse Keeps Blowing!
Old 04-21-2005, 12:38 PM
OdessitPashka's Avatar
Last night I got into my car, started it, turned the lights on, and my cluster light turned on and then off, along with my parking lights.
Today I checked all the fuses and one that's inside the engine bay that's for " Right Tail" or something was blown, I replaced it, and it blew again.
I checked for shorts, but visually didn't find anything.
Old 04-21-2005, 03:27 PM
sure it wasnt for the left tail?
and you know that along with a post like this you gotta tell us if you have done anything lately. wink1.gif
Old 04-21-2005, 03:30 PM
yes, we need ALL the details of what you may or may not have done to the car recently.
Old 04-21-2005, 07:23 PM
<div class='quotetop'>QUOTE (tibby01 @ Apr 21 2005, 04:27 PM)</div><div class='quotemain'>sure it wasnt for the left tail?
You are right, it was a left tail and left parking headlight.
I installed my sub the other day. Didn't really cut any wires or anything. Just connected power wire to the battery, run it into the trun through outside, run accesory wires through the car from my stereo. Sub and amp work very well, so it can't be something related to them....
Please help!
Old 04-21-2005, 07:31 PM
i say go back behind your head unit and check to see if you mmessed with the illuminations wires(green/white and green/black).
Old 04-21-2005, 07:35 PM
Those wires were not touched when I installed the sub.
Old 04-21-2005, 07:39 PM
if you used a remote wire to turn on the amp they should have been shifted around atleast.
Old 04-21-2005, 09:56 PM
why is that? I had a separate wire coming from my radio that said "REM AMP" and I just connected it to the amp.
Old 04-21-2005, 10:40 PM
zoned019's Avatar
Vehicle: 97 Tib
http://www.rdtiburon.com/index.php?showtopic=6805
Old 04-21-2005, 10:45 PM
Could you remember what you did about this man?
The weird thing is that I didn't touch anything for the sub, just connected "REM AMP" wire to the amp and 2 other wires from the HU to the amp. Don't know what I could have touched or done to make it like that!!!
