Need Help
Vehicle: 1997/Tiburon/FX
The other night I was turning onto the bend towards my house, then I heard a loud screetching noise when I turned my steering wheel either way. It became real tough to move the wheels so I left her on the curb infront of my house. I checkd it out and noticed when I go to turn the wheel that the pulley on the power steering pump stops moving and makes a screetch noise. I changed the pump but I think it was bad because I still had the same problem after the new 1 was on. Now my new one comes in tomorrow, but IF its not the bad pump what else could it be? I need some help here guys. Thanks!
if you need another pump, i have one that works perfect and ill get rid of it for cheap. let me know. also, make sure ALL belts are tight. i had a loose alternator belt and it would screech like that
If I need another Ill let you know, all my belts are tight I believe. Though I doubt that would cause a pulley to stop lol. Ill double check just in case
