My Blinkers Are On Crack!
Yeah, I'd say it's a bad connection somewhere, it COULD be fuse related as in the fuse for it could not be seating correctly. I had this happen for my rear window defroster.
Replace the flasher unit. It won't be a bulb or fuse. I've had them go b4 and that's exactly what they do.
You should find it up under the dash (have a look on webtech).
that's odd, cause i don't have that option.... maybe im not looking hard enough... but you're talking about the very top banner of and where is says garage gallery arcade help etc.... nope, not there.
mine says (banner) INVISION POWER BOARD
below is RDTiburon.com to the left
& the rest on the right are in this order. Garage, Gallery, Arcade, Help, Search, Members, & Calendar.
no flashchat option.
ha!!! i figured it out... i changed my background 2 RDLime & now i have the option. cool.
Definatly sounds like a turn signal flasher. If they work just fine at first and then go nuts, that's where I would go first. I have seen several of them go bad and make the turn signals go nutty. From working fine, then all of the sudden stay on or off, and even hearing the flasher unit makeing buzzing noises.
