My battery light in the dash doesn´t show.......
Old 11-02-2004, 07:04 AM
sharkev's Avatar
Default Re: Java's Clearance Sale
I know that my alternator is working fine, because I sent it to a check and they tell me that everything in it is fine, and is charging my battery at 14. more or less......
Old 11-02-2004, 04:02 PM
Cuervo79's Avatar
Vehicle: 2010 Genesis Turbo
Default Re: Airbag legality question?
you had time to pull the whole cluster off? dang I need to get my time together, do you have a voltimeter to check that the connection has power?
hey si desarmaste por completo para ver que tipo de luz era no te saldria facil encontrar los cables que le dan poder a las luces del cluster?
Old 05-11-2005, 10:39 AM
sharkev's Avatar
I still have the problem. I already check a lot of things and everything looks fine.
any idea?
about the power cables, i didnt check that.
Old 05-11-2005, 11:05 AM
'treezy's Avatar
my car doesn't have that battery light option. It's not really an "option" per se, but it has never lit up. The little cut out on the cluster is there but the light never comes on (when key is turned to on). Maybe your car just doesn't do it. You have a rd2 tho, so it probably should. Did the light come on before you started messing with your cluster?
Old 05-11-2005, 11:07 AM
sharkev's Avatar
no. i have never seen that light turn on.
but I have seen another tibs around just like mine with that light on.
so, I dont know, maybe you are right, not every tibs are like that.
Old 05-11-2005, 11:12 AM
'treezy's Avatar
yeah, don't worry bout it. Your car isn't cool enough for that feature.
all these people freakin out and thinking you're alternator is going to blow up because light don't work, haha. shaddup....me no speaka englas esee........ ninja.gif
