My battery light in the dash doesn´t show.......
Re: Horse power gain and overal
my battery light in the dash doesnt show, i saw a few advice to correct that in this page
http://hmaservice.com/webtech/
Charging warning indicator does not light with ignition switch "ON" and engine off
Fuse blown
Check fuses..........already checked
Bulb burned out
Replace bulb...............already checked
Wiring connection loose
Tighten loose connections
Electronic voltage regulator faulty
Replace voltage regulator .....................already checked someboyd says.
but i dont know where are the wires that there says that maybe are bad, can anyone help with the other thing that I have to check?...... somebdy can tell me where are these wires?....
thanks...
Fuse blown
Bulb burned out
thanks...
You say you checked the bulb, what kind of bulb is it? LED or Incandecent?
Re: the kspec crazy dude...
<div class='quotetop'>QUOTE (REDZMAN)</div><div class='quotemain'>You say you checked the bulb, what kind of bulb is it? LED or Incandecent?</div>
I dont know the difference, but it a little bulb and lights a little yellow, I think its a LED, but not sure.... what are the difference?!
Re: My battery light in the dash doesn´t show.......
The LED ones are Polarity sensitive. If it's LED and not working, pull it out, and put it in backwards.
Re: Search problems
if its a stock unit its an incandescent. meaning that if its working properly, it shouldn't matter how its inserted into the cluster.
When you had the cluster out, did you happen to notice any cuts or looseness on the printed circuit sheet?
it could just be a bad contact from there.
Re: What is the best way to start with an automatic......??
hmmm.. now I have to wonder if your alternator is charging. Many alternators need the battery light to come on before they start that intitial charge after starting.
Vehicle: 97 Tib
Re: Gauge Group Buy GREAT DEAL from Splitfire!! NOW TAKING M
you probably don't have the cluster pushed ALL the way in tightly and screwed down completely, the light that lights up my needle on the water temp gauge stopped working until i removed it and replaced it..that pc board in the back is weird.
Re: OZ-BBTB
ok... now .......first my alternator is working fine!... the bulb is ok, too.... everything LOOKS fine, but till today i couldnt find the problem...... i dont know what else check.....
i dont know... what can I do.... ??.........
anymore ideas?
thanks
anymore ideas?
thanks
