Most Effective Oil Catch Can
Vehicle: 97 Tib
Because then #1 you have no vacuum on the PCV, so it will never open, so you basically are doing nothing..
#2 you are not filtering the "breather line" between the intake and block
Yeah, 2 catch cans would be the best.
option 1 would change the point of vacuum from the PCV valve to the breather. Basically, you'd be sucking air from the intake instead of the engine
I have no clue why you read that. It dosn't make much sence. the point of the catch can is to strain the liquid from the air. As long as it starts and ends at the same point, up and down won't effect anything except distance.. Down towards the catch can would make it work easier as the oil will be forced into the catch can instead of hanging around in the lines.
Vehicle: 97 Tib
Sorry h-bomb, my mistake.
That would work, but then how do you filter the intake side of it?
Also, with an air filter on the can you spew oil all over the bay..
Okay well, i dont know if its different if you have a turbo setup or not, but i just removed my pcv valve, put in a fitting and have both those two lines going to the side of a can that i put a little air filter on top. Probably not the best set up, but it only cost me 6 bucks to make and it looks nice
Vehicle: 97 Tib
h-bomb, doesn't that spit oil all over your engine bay? and what about the intake side?
<div class='quotetop'>QUOTE (LarryMcFly @ Mar 10 2007, 07:57 PM) <{POST_SNAPBACK}></div><div class='quotemain'>One thing that has been missing and that makes a BIG difference in your catch can setup, the can MUST be higer than the source (pcv valve).
The hose need to point up, not down. This way, only the oil fume will end-up in the can, the oil will not go up the hose at high revs/loads. If the hose points down, everything will flow in the can and create a mess.</div>
http://www.rdtiburon.com/index.php?showtop...mp;#entry285839
That's the post I was talking about^^
Is that true?
It kind of seems like the guy got it mixed up. You need to be LOWER than the source..? Although, pressure still shouldn't be affected.
Is that true?
Mine is boosted so, hopefully it's okay... lol
I ran both the pcv and the intake line to the can. I havnt driven it a lot since i installed it so i dont know how effective it will be, so sorry I cant give you any "for-sure" answers, only some ideas.
Vehicle: 97 Tib
So you T'ed them? With a filter going to atmosphere on your can you haven't gotten oil in your bay? Have you caught much yet?
