mods to get into 15s?
any mods that will get me into the mid 15s, lower 15s by any chance?
iam running a 16.8, was wondering what esle i could do to get a lower time on the track. Would spraying a 50 shot help or is that just a bad idea to spray on a tib?
![](https://www.hyundaiaftermarket.org/forum/images/ranks/admin.png)
50shot is fine if you know how to use it and can use it sparignly and carefully.
I would consider cams, pulleys, and BBTB/IM (check the KSPEC group buy going on)
those will definitely help you (especially BBTB and IM)
^^exactly what majik said, but i do have to add : BOOST and a lightwieght flywheel.
also, when you run at the track how much of your interior do you have in....if you race w/ the full interior....try stripping it before going to the track.....you should be able to pick up a couple tenths right there.
Vehicle: 97 Tiburon
^^ yup. when i hit the track for the first time, my rear seat will be gone, as will the spare tire and anything else that is bolted down
get your car as light as possible...and maybe you can even go on a diet tongue.gif
yeah, I always thought about these fat people who strip their interior to get it 10lbs. lighter... if they'd just get their weight down that's be a huge reduction in itself!!
also.. you still have the stock cat? I do not see that listed in your mods. Also, how is your clutch? believe it or not.. a slippery or even an old clutch can cost you a few tenths as it slips..
or you can just strip your car down, take off the stuff you don't need to race at the track...shift your ass off. i think you can get into the 15's.
I have a 2000 tiburon and I put a powerchip in my car and it took off half second. I think the website is www.powerchip.com
Vehicle: Hyosung GT650
Hey paintballpinup, welcome to the site mang. Where are you (Fill out your profile please)? I've mensioned the power chip before, but you are the 1st person I know that's fitted 1. How good is it and is it worth the cost?
