Leaky Injector From O-ring
ill just go pick up another full NEW set of o-rings tomm. and then make sure the bungs are really clean, then use some nice clean oil to lube em hope..
hope it works..
thanks alot guys.
hope it works..
thanks alot guys.
The best way to find exactly were the leak is coming from is to use a thing called dye penetrant developer. Basically it is a liquid powder, you spray it on like a aerosol paint can, and in about a minute it dries to a powder. start your car and look for the fuel to start dampening the powder, it is very specific and will tell you exactly where it is coming from then check out whats the deal..but maybe you actually cracked an injector when the rail popped of, might have put enough of a side load on it to do that..best of luck man..ohh lets us know what you find
Vehicle: Elantra XD GT
<div class='quotetop'>QUOTE (Denisst99 @ Jun 1 2007, 04:18 AM) <{POST_SNAPBACK}></div><div class='quotemain'>use petrolium jelly (vaseline) to lubricate the O rings</div>
