Jspeed Power Pulley
Old 06-16-2006, 03:54 PM
funkypc's Avatar
for the correct belts, its going to be a bit of work. noone has the belt numbers for you, so you are going to have to take your current belts off, and go to your local part store - AKA autozone - and ask them for a belt that is a little bit smaller then the current one.
And it may take you a couple trips of returning the old belts and getting different sizes.
But once you get the right ones, be sure to post it for other tiburon owners that do the same thing in the future!
good luck!
Old 06-16-2006, 04:05 PM
Role Reversal's Avatar
Vehicle: 05 Subaru WRX
You should be able to use that same belts if you got the power set. You can adjust your alternator and your power steering pump. If you got the crank pulley you will need new belts.
Old 06-18-2006, 03:44 PM
JGeZau's Avatar
Oh, OK, thanks guys...one last qestion, do i have to change all of the belts or just one? if so, which one? Thnaks... sad.gif
