Interior Lights
Before I start, I tried searching. I didn't find anything on interior lights specifically not working.
Well, I was trying to make my door dinger shutup. I can't stand the sound. (All lights worked). Well I found the black box under the dash where it was. I was tracing the wires to find a pigtail connector but I accidentaly pulled on the blue wire leading to the dinger box. The dinger shutup. (Pigtail still connected) Well I notice my door lights, clock, and console lights don't work. I don't think it's bulbs. How could they all blow at the same time? Possibly a bad ground? I have checked all fuses. All were good. I'll get pictures under my dash later, I think the previous owner, or hyundai did a bad wiring job. I have 3 black boxs under the dash with in-line fuses (checked these too) and connectors with some leading to the ECU relay. It just seems like someone was tampering with the wires. Most are Zip-Tied together. Anyway, what are somethings to check for the lights and clock? Everything else works fine. Any help is appreciated.
*Side Note* I notice my door ajar light and hatch light on the cluster don't turn on either. I would assum those are bulbs. I will check this weekend. But could they be on the same circuit as my interior lights?
Thanks to all.
Thanks to all.
Check your fuses. Check the fuses in the engine bay.
Those circuits aren't really related. The doors are on constant power and the clock is on hot-at-on power.
I checked the ones in the engine bay. I'll check again though. I hope it's just a fuse.
EDIT** I just re-checked all engine bay fuses. They all are good. Interior fuses checkout too.
Vehicle: 2000/Hyundai/Tiburon
if you only checked the ones in the engine bay, then you probably wont find much to help you with any accesories, basically all of the accesory fuses are in the cabin, down by the pedals
when i disconected my door dingers in mine all the interior light quit working and the clock also the door ajar and trunk light quit coming on as well. so i would check all the wires for anything to do with the dinger box or connectors on the door jam... maybe something with the blue wire that u pulled by accident...
Well I feel stupid. The one fuse I skipped over. It was #6 inside the cabin. duh.gif Geez. Sorry for making a topic over a fuse. But thanks for those diagram DTN. I saved them. Thanks to all.
<div class='quotetop'>QUOTE (BrandonR @ Oct 9 2008, 11:38 PM) <{POST_SNAPBACK}></div><div class='quotemain'>But thanks for those diagram DTN. I saved them.</div>
You can get the rest along with shop manuals at www.hmaservice.com username rdtiburon.com password tiburon.
