I'm Just Curious
Old 04-02-2007, 05:34 PM
Caj Darkmoon's Avatar
Strut Bar ~60-120
Diamond Plate Aluminum floor mats ~ 50 if someone's selling them
Clear corners ~60
Painted Dash ~40 for supplies
Short Shifter ~75-100 for the Megan or ImportShark STS
Euro Tails ~75
There's a short list for ya.
Old 04-02-2007, 05:35 PM
frozen's Avatar
Vehicle: 2001 Tiburon
buy a dent puller and take out the dent.
if you're electronically inclined, look up tibby01's LED needle mod, or check out some of the other LED projects if you want to make it look good. also see the resonator removal diy, or get an ebay cai. change your oil, air filter, fuel filter, tranny fluid, etc.
Old 04-02-2007, 05:50 PM
Kantizuni's Avatar
Vehicle: 2000 Turbulence
Throw in some LEDs. If you've put in neons, you'll want to switch to all LEDs once you've put a few in.
Check the DIY section, there's a few ideas in there. Especially the windows switch/door handle LEDs, and the shifter surround LEDs.
edit:
This is what my shifter looks like in the dark. Probably the coolest mod i've done on the interior (in my opinion). And cheap.
Old 04-02-2007, 06:26 PM
Rd1tib's Avatar
go make urself a front lip from homedepot.
Old 04-02-2007, 07:12 PM
StrikeEagle's Avatar
I'd second the LED idea! And I can help you out with any LED project. You can get 100 LEDs and resistors for a couple bucks on eBay, and can do an infinite number of projects with it. You'll need a cheap soldering gun ($20) and some electrical flux (~$3), and you're good to go.
Forget the dent puller, just get a hair dryer and electronics cleaner (it's a bottle of CO2 with a nozzle and trigger). Warm the spot with the hair dryer for a minute or two, then turn the bottle of cleaner upside down so the liquid CO2 comes out the nozzle instead of the gas. Spray the liquid CO2 on the dent for a short bit, then as the frost melts, "pop!!" out comes the dent.
Old 04-02-2007, 07:20 PM
Does that really work?
