Idel Problem
Old 04-24-2005, 04:56 AM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
I have the same. And my father's car does it. And my previous car did that.
I think it's ok.
Old 04-24-2005, 05:34 AM
Viper's Avatar
Old 04-24-2005, 08:07 AM
turbulence's Avatar
if you're cruising to a stop and take the car out of gear, the rpms will rest above 1000 rpms to help synchronize the gear shift in case you downshift. once you come to a complete stop, the rpms rest to normal idle. that's the way it works, unless i'm misreading your problem.
Old 04-24-2005, 08:52 AM
CyberShark's Avatar
My car does the same thing, it'll float momentarily above a grand in neutral when I'm slowing down and eventually drop to idle.
Old 04-24-2005, 12:57 PM
AllEyesOnME's Avatar
what happens is when i take it out of gear and come 2 a complete stop it takes a long cple of sec before it drop to 1000
Old 04-24-2005, 01:06 PM
hamhead's Avatar
Thats normal. laugh.gif Like stated before, it does that to help synchronize gear shifts for those who do not rev match when downshifting to a much higher RPM.
For example, if your going 80 in 5th gear, and put it in neutral, it will float to around 2400, stop for a second, drop to 1600, stop for a second or two, and then drop to around 1200, then settle in neutral.
Old 04-24-2005, 01:30 PM
Dmitry's Avatar
It could also be to make brake booster work better.
Old 04-24-2005, 01:32 PM
CyberShark's Avatar
<div class='quotetop'>QUOTE (AllEyesOnME @ Apr 24 2005, 06:57 PM)</div><div class='quotemain'>what happens is when i take it out of gear and come 2 a complete stop it takes a long cple of sec before it drop to 1000
You got nothing to worry about, that's normal too.
Old 04-24-2005, 09:10 PM
it seems odd b/c it didnt do it before
Old 04-25-2005, 03:44 PM
silvertibbs's Avatar
Vehicle: 2004 Acura TL
You mean like before your mods?? Cause that could be the cause too. The ECU is seeing a little bit more air and is prolly playing it safe as not to mess up the tranny at all. [/$0.02]
