I Need A Ho Alt
Vehicle: 2001 Tiburon
At least get you started. Prices may be dated, did not check the links.
http://www.rdtiburon.com/index.php?showtop...lternator\
I dont believe there is one for us anymore. You could get yours redone for higher output but it wont get you that high. Or use another one of some other car and do a custom bracket of some sort. Why the higher output needed?
You shouldnt need one that big. Just a suggestion but maybe look into a dual battery setup. Would be far cheaper and easier to do in the end with better results. Im going to be running 2500w rms with a dual battery setup. No need for the huge alternator.
I have dual batteries. Problem is our alt doesn't keep the voltage high enough. The batteries stop headlight dimming but just not enough over all. I found a 140 amp alt for 300. My last system was pushing over 2500rms, and this one is sponsored and will run over 3000rms at shows.
