Hids Don't Like My Fuse.
Old 08-01-2006, 04:02 PM
Kantizuni's Avatar
Vehicle: 2000 Turbulence
Jay-M.
I tried everything y'all suggested. Nothing worked, until I removed the ballast from where I had mounted it, away from touching metal. So far both lights are coming on, everytime. So now my new question, is where is a good place to mount it? I would check through the garage/gallery for underhood pics, but apparently it's not working right now. 02.gif
Any mounting suggests for the drivers side ballast?
Old 08-01-2006, 04:46 PM
awesome!! yep Jay-M, our good HID man got it. mounting?! easy. take out the battery and there should be a little snug place for it on the side wall right behind the corner signal. i didn't even mount mine. you can use double sided tape.
Old 08-01-2006, 05:05 PM
Kantizuni's Avatar
I just checked there, and I see a little grey box that says "VCV (korean babble)" mounted there. Did you mean to mount the ballast below that? And what is that box anyway? o_O
Old 08-02-2006, 03:18 PM
ooo ooo....kant,
check out my post here:
http://www.rdtiburon.com/index.php?showtop...&hl=ballast
Old 08-02-2006, 07:54 PM
hprockets's Avatar
Vehicle: 2009 Hyundai Sonata
<div class='quotetop'>QUOTE (Kantizuni @ Aug 1 2006, 11:05 PM) <{POST_SNAPBACK}></div><div class='quotemain'>I see a little grey box</div>
that's the daytime running light module. remove the connection, and your daytime running lights will turn off!
Old 08-02-2006, 08:16 PM
Jay-M's Avatar
Vehicle: 01 Tiburon
<div class='quotetop'>QUOTE (Kantizuni @ Aug 1 2006, 05:02 PM) <{POST_SNAPBACK}></div><div class='quotemain'>Any mounting suggests for the drivers side ballast?</div>
hope those pics help
Oh also, to insulate it i recommend using this http://tst.glad.com/pressnseal/: wrap it all around. It works like a charm and the mounting is solid!!!
Old 08-03-2006, 06:22 AM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
I know there are 2 types of HIDs - for negative ground and for positive ground.
If you have wrong HID you need to insulate it. Maybe you need to insulate ballast?
Old 08-03-2006, 07:42 AM
Kantizuni's Avatar
Ohh... when I have some spare time and more ambition... I like your idea Tibby01. Definately looks cleaner. Thanks for all the suggestions, guys. smile.gif
