Help With Sunroof
Vehicle: 2004 Dodge Neon Srt-4
the weather stripping around mine is coming off, so i need to remove the sunroof in order to re adhere the stripping.
Just wondering how you go about removing it from the car?
If you are logged into webtech this should work:
http://hmaservice.com/viewer/content.asp?u...^37787^shop^%24
Never done it personally but it's the 2¢ I got right now
not hard whatsoever....
only (4) 10 mm nuts to remove after you pop off the inside cover. i take mine out once in awhile to detail that area and give the track a good lube.
<div class='quotetop'>QUOTE (UrS0NvS @ Jun 25 2010, 05:03 PM) <{POST_SNAPBACK}></div><div class='quotemain'>not hard whatsoever....
only (4) 10 mm nuts to remove after you pop off the inside cover. i take mine out once in awhile to detail that area and give the track a good lube.</div>
are u talking about the inside cover, as in the headliner?.
<div class='quotetop'>QUOTE (UrS0NvS @ Jun 25 2010, 04:03 PM) <{POST_SNAPBACK}></div><div class='quotemain'>i take mine out once in awhile to detail that area and give the track a good lube.</div>
went and looked at it today.
Didnt realize just the sunroof part itself came out that easy. Popped that liner piece of, and sure enough there was 4 10mm nuts holding it on! thanks guys
