Help! Starting Issue..
Old 04-25-2005, 05:13 PM
  #41
col96fx's Avatar
Vehicle: Hyosung GT650
<div class='quotetop'>QUOTE (col96fx @ Apr 21 2005, 08:15 AM)</div><div class='quotemain'>When you cleaned the terminals, did you do like I said and take them off and clean them with sandpaper on the post and inside the connector. There could be a layer of corrosion there even if you don't notice it.
<div class='quotetop'>QUOTE (zoned019 @ Apr 22 2005, 02:35 PM)</div><div class='quotemain'>so i take it back out to my car and then i notice that my loops are corroded as HELL. they look fine when they're on a battery, but once you disconnect it you can see the bottom of them and it's a thick white ring..i scratched those off with the only thing i could find---a ratchet. popped in the wal-mart battery and it started on it's own. yay!
Mang if you ask for help and ppl give advise you should at least check out what they're telling you. I told you to check for corrosion and you obviously didn't even take the connectors of the post to have a look, if you had taken this advise you would have saved yourself alot of heart-ache. <_<
Old 04-26-2005, 09:33 AM
  #42
zoned019's Avatar
Vehicle: 97 Tib
i know i'm stupid, i did take them off. i cleaned the inside and outside, but didn't even realize or notice the underside (until it was two days later anyway). it was a pretty thick layer too.
im keepin the new battery in there and cleaned those suckers good, threw a lot of white grease on em and should be good to go.
