Help Pleast Tibby Trouble
Old 06-20-2008, 12:17 PM
zoned019's Avatar
Vehicle: 97 Tib
You could start by reading this thread ..
Old 06-20-2008, 03:24 PM
shortyg83's Avatar
As far as miles go. I have 115000.
Yes I have a CAI could maybe use a new filter.
plug wires go bad?
Old 06-20-2008, 06:33 PM
stealth's Avatar
Vehicle: 2000/Hyundai/Tiburon
well, i did read the thread, but i dont seem to have the exact same problem as him, as to why I asked if any of the stuff you guys were saying would help me or if anyone knew what was wrong with my car.
Old 06-21-2008, 11:00 PM
enigo's Avatar
Vehicle: 97 Tiburon Fx
My thoughts:
Yes, wires do go bad. If you're going to get replacement, PRD wires are an excellent product with a lifetime warranty. Far as testing the wires... omh meter, and check to see if the resistance is correct.
Though from the sounds of it, your IAC needs to be cleaned out. Try taking some seafoam to it for cleaning (search for how to do that) and then lube it with some silicon gel (DTN explained how to do that as well).
yellow: Do the seafoam clean up, lube your IAC, check your wires & plugs
Old 06-23-2008, 08:25 AM
zoned019's Avatar
Vehicle: 97 Tib
<div class='quotetop'>QUOTE </div><div class='quotemain'>well, i did read the thread, but i dont seem to have the exact same problem as him, as to why I asked if any of the stuff you guys were saying would help me or if anyone knew what was wrong with my car.</div>
YES, you have idle problems too.
shorty, did you try any of the things suggested?
Old 06-29-2008, 08:41 PM
shortyg83's Avatar
I checked the spark plugs they are good. Put on new cone filter on. Clean the 2 sensors in the cai but still nothing.
Here is the thing when I reset the ecu the car works fine for about 20 miles or so.
Could it be the MAF or what do you guys think? The CEL no longer comes on.
Any other ideas?
Old 06-29-2008, 08:49 PM
If you have a bad MAF it will likely act up more but you can check it by unplugging it. If the problem goes away, your MAF is bad. You have to unplug it when the problem is occuring though.
What brand TPS? Thats the sensor on the throttle body.
And you may still have a code stored even if the light shut off. Get it checked if you can.
