Help ! Crazy Problem
Old 03-27-2006, 02:58 PM
BIGTRE13's Avatar
Ok I changed engines, long story, the problem now is that I keep blowing fuses. The fuse for the computer to be exact.
This only happens when .......
1) Car is warm
2) RPM's stay over 3500 (can go up and down w/o problems)
3) Only when car is in motion
Any help woud be greatly appreciated. I really miss driving my car.
Old 03-27-2006, 03:08 PM
zoned019's Avatar
Vehicle: 97 Tib
You keep blowing the ECU fuse?
Old 03-27-2006, 03:11 PM
BIGTRE13's Avatar
yes sir, thats the only one
Old 03-27-2006, 03:23 PM
supercow's Avatar
did you swap ecu's as well?
Old 03-27-2006, 03:38 PM
BIGTRE13's Avatar
no, just the engine
Old 03-27-2006, 04:18 PM
JonGTR's Avatar
You cut one of the sensor wires and it's grounding out somewhere.
Old 03-27-2006, 04:30 PM
BIGTRE13's Avatar
which sensor could it be ? the car has been checked by 3 different mechanics and still no luck
Old 03-27-2006, 04:39 PM
Hyundaidb883's Avatar
when you swapped motors, did you re-use the old harnesses?
Old 03-27-2006, 04:45 PM
BIGTRE13's Avatar
yes the only thing I changed was the motor
Old 03-27-2006, 05:28 PM
i'm going to make the assumption that it worked properly before. i don't have my electrical manual with me, but if you do, does the ecu fuse you're talking about send power solely to the ecu, or does send power to other sources as well?
