Help...
DIY section mang. Sticky post in there has a link to all the DIY's.
http://www.rdtiburon.com/index.php?showtopic=50
Or the search link at the top of the forums.
Click here for the finished search.
Found it in like 2 seconds.
Vehicle: 97 Tiburon
the reason it prolly didn't come up is because of your forum settings... either you have it set so the forums only show you like the posts from the past month, or your search field wasn't set properly...
either way, glad ya found it. its quite easy. 4 10mm bolts i believe
easy peasy, Japanesey
