Headlight Issue
Guys, this may not be in the right spot, but it seemed to be the best fit
My headlights and "position light" on the passenger side appear to have some water on the inside of the lamp. Has anyone else encountered this problem, and if so what was the fix? I suspect there is some sort of gasket that needs to be replaced. I have a set of shop manuals on order but they have not arrived yet. I have a burnt out healdight, so I need to fix this as soon as I can
I've never heard of anyone having that problem with the headlights but the leaking position lights is pretty common. You can either try to seal them with some clear silicone (at the joint between the lense and the housing) or purchase new ones (best bet is probably www.kspec.com).
Vehicle: 1997/Hyundia/Tiburon Fx
A easy fix and you can find a DIY on headlight painting here on the site.. Or you can do like I did and take a heat gun to the seam pull apart paint inside bezel and re-seal that way it looks better and no more moisture.
