Head Removal
Old 12-18-2005, 12:43 PM
you can use something in place of that im sure.
Old 12-19-2005, 09:45 AM
JonGTR's Avatar
You just use an allen wrench on a breaker bar. It's not anything special. you should be able to find the allen socket at Sears or maybe the parts store.
The bolts are torqued to like 60lbs, so they're on tight. Take them off from outside to inside.
Old 12-19-2005, 10:05 AM
wattsup4800's Avatar
do you know the diameter of the allen wrench? And if they are all the same size?
Old 12-19-2005, 10:31 AM
Casper's Avatar
2 different sizes, not sure what the sizes are. Use some alans you have lying around to find the size. Then match them in the store.
Old 12-19-2005, 11:09 AM
ill try it out, is it def only 2 sizes?
Old 12-19-2005, 11:40 AM
JonGTR's Avatar
Yes. There are two bigger bolts on the right side under the cam sprockets. Then there are 8 others of a smaller size.
You should check into ARP studs. I got mine for $125. the part #'s are in the turbo section.
Old 12-19-2005, 12:15 PM
what are arp studs?
Old 12-19-2005, 12:35 PM
Studs, made by the company ARP.
Old 12-19-2005, 12:37 PM
what are the benefits?
Old 12-19-2005, 12:50 PM
Casper's Avatar
There stronger than the stock bolts.
