Getting Rid Of A/c "stink"
Old 07-01-2005, 09:02 AM
Spiffywerks's Avatar
Well, its been a while since I used my A/C, since it was depleted. Got it fixer'd up again, but when I turn it on, it has this kind of a mildewy smell for about 30-45 seconds. Anyone have some tips on how to clean up the A/C to remove this smell?
Thanks ^^
Old 07-01-2005, 09:14 AM
UltraTibby's Avatar
I have seen this caused before when the coolant became depleted for an amount of time and was then recharged. Really the only way to get rid of the smell is by running the AC a lot. It will eventually clear everything out (atleast it has for me in the past).
Old 07-01-2005, 09:15 AM
here we use a thing called frigifresh
they sell it at autozone i think
zoned019's Avatar
Vehicle: 97 Tib
Yeah. Like the first day of summer that you need to use it it usually smells a bit too. Just let it run for awhile, eventually it will clear up.
Old 07-01-2005, 09:17 AM
UltraTibby's Avatar
<div class='quotetop'>QUOTE (faithofadragon @ Jul 1 2005, 11:15 AM)</div><div class='quotemain'>here we use a thing called frigifresh
What exactly is it and where does it go?
Old 07-01-2005, 09:20 AM
Frigifresh. I'll check this out. Thanks!
Old 07-01-2005, 09:22 AM
javageek's Avatar
They sell stuff like that here as well. I used to have a bottle but EVERYONE wanted to borrow it after they rode in my car and noticed I didn't have "The Stink".
To use it I believe you turn your AC on full blow then you spray this stuff down by the air intake which is in the passengers foot area. I believe you are also supposed to put it on vent and go outside and spray it in the intakes that are below the windshield. It tells you exactly where to spray on the bottle.
Old 07-01-2005, 09:36 AM
supercow's Avatar
I've actually heard of people using lysol for that exact same purpose java, I read an article or something about it when i was trying to get the smell out of my 75 cutlass. but it went away and i didn't worry about it anymore. sooo you might wanna try some lysol...
Old 07-01-2005, 09:38 AM
you spray it into all of the vents
then you run the a/c
its like lysol but wont rip the crap out ofyour lungs
Old 07-01-2005, 10:30 AM
javageek's Avatar
^^ But you need to ensure you spray it in the AC intake as well. Otherwise your not killing the mildew that is through the system.
