Gauge Lights
Old 07-30-2009, 09:56 AM
Shark Bite's Avatar
I recently had some strange electrical problems with my new tib. dealership fixed everything for me at no cost and upon receiving my car I realize that night that numbers on my gauges don't light up at night. only the needle for the gauges and the odometer are lit, but nothing else. Blown/missing dash bulb perhaps? or should I just head to a junkyard and buy a new set of gauges
Old 07-30-2009, 10:20 AM
Turning right back around and telling the dealership to fix the lights that they broke is not an option?
Old 07-30-2009, 02:05 PM
Shark Bite's Avatar
Well The lights hadn't worked when i first got it so they didn't necessarily break them, i just think driving the 60 miles to fix a dash light is too much (bought car with my dad who lives upstate) so i'd rathr just get the part and DIY.
Old 07-30-2009, 10:59 PM
Check your dimmer.
Old 07-31-2009, 03:13 PM
Shark Bite's Avatar
checked that as soon as i spotted the problem. I was planning on getting some reverse glo gauges, but reading around here i learned that those stopped selling 1-2 years ago =/
Old 07-31-2009, 04:39 PM
likeyoumeanit's Avatar
I have a spare set of gauges I would be happy to ship you if you want a set to mess with
Old 07-31-2009, 05:52 PM
Shark Bite's Avatar
Stock I assume? And that would be absolutely fantastic You_Rock_Emoticon.gif
Old 08-03-2009, 11:22 PM
frozen's Avatar
Vehicle: 2001 Tiburon
Speedhut makes EL gauge faces for us. We had a GB a while back on them. Should be available on their site.
Have you taken apart the gauges yet? For all you know it could be a couple of blown bulbs. So the needles on all of the gauges light up... But none of the gauges (RPM, Speedo, Fuel or Temp) light?
Are the needles supposed to be lit all the time, or only when the rest of the gauges are lit? If it's supposed to be on with the gauges, then something is wrong with the cluster or the bulbs are blown... Either way, it's fairly easy to check once you have the cluster taken out. If you look at the back of the cluster, it's pretty straight forward.
Old 08-04-2009, 06:18 AM
Shark Bite's Avatar
Yah, the needles are only supposed to be lit when interiors/headlights are on. those work fine, its just the speed, rpm, fuel, and temp faces that don't light. most likely a bulb, or maybe a relay isn't connected or something?
Old 08-04-2009, 09:59 AM
frozen's Avatar
From what I can see on webtech, all those bulbs are connected together. But it's not very descriptive. Best way is pull it apart and look.
