Gas Pedal Squeeking ?!
Old 12-04-2007, 09:13 PM
BlueShark's Avatar
Hello,
There is my annoying problem: When it is very cold inside the car, the gas pedal squeal each time that i lightly press on it. The squealing appears when the pedal is released, not pressed. I try to grease the spring, nothing. The only time it stops is when the cabin is warm up. The sound can be compared to leather to leather noise lmao.gif
Any ideas ?
Old 12-04-2007, 09:27 PM
Tiburonmoo's Avatar
Vehicle: 2000 Tiburon
Dude, I think that's your shoe against the pedal. Try wearing different shoes.
Old 12-04-2007, 09:47 PM
BlueShark's Avatar
No, impossible cause i have snickers (yup in winter) and that the break pedal doesn't make noise. And i looked underneath the dash, nothing is rubbing.
Old 12-04-2007, 09:57 PM
drewinator's Avatar
Vehicle: 2000/Hyundai/Tiburon
I have the same problem, but its more of like a bubly squel if that makes sense.
Old 12-04-2007, 10:53 PM
you have to take the pedal out. Its easy, but you gotts be careful. Its clipped to the throttle cable. Its tight but dooable. Once pedal is out there is a spring clipp. Its likely rusted or needs to be regreased. You can buy all purpose grease from auto part store.
Old 12-04-2007, 11:17 PM
BlueShark's Avatar
drewinator: yes you can say that, it could be the same as per you have the model car that i have.
HyundaiKitCoupe: Yes, i did grease the spring clip as you mentionned, but i didn't remove the pedal. It is very difficult to see the spring clip since it is located in the inner right side of the pedal, i bang my head so many times chairshot.gif It did help for a while, like 1-2 days, then the noise restart. I wish i can remove that spring to see the condition and grease it good.... i can't find any instructions at hmaservice.com.
Old 12-05-2007, 11:57 AM
<div class='quotetop'>QUOTE </div><div class='quotemain'>i bang my head so many times</div>
hahaha i did too, soo much. i'm 6ft4.
are you certain that is where the noise is coming from? is the spring rusted? your problem could be elsewhere and more serious because what would heat have to do with it...
you mention it sounds like leather, i did a google search, one thing that came up is it could be coming from your rotors/pads. when you release the gas the car is deccelerating so check your rotors to see if one of them looks warped, or has a texture in it.
Old 12-05-2007, 06:27 PM
What do snickers have to do with this thread?
Old 12-05-2007, 06:44 PM
haha.gif Ya, you are back. lol He meant sneakers (as in shoes) I believe.
Old 12-05-2007, 07:50 PM
BlueShark's Avatar
No, i'm 99% certain of the noise location. As for the rusted clip, it's very hard to see by the location of it.
