Gas Mileage Going Down And Down And Down And....
Old 03-19-2006, 01:05 AM
lilo shark's Avatar
fix your cat then post again cause a clogged cat will fo a lot for gas mileage.
Old 03-19-2006, 08:59 AM
things you need to do:
1: fix wheel bearing
2: check alignment (should be done after a wheel bearing change anyway)
3: check tire pressures
4: get a new cat
5: do a compleat tune up (filters, plugs, and wires)
Not necessarily in that order.. do the easy cheap ones first.. but you definatly need to get that cat replaced ASAP. Not only is it killing your performance and miliage.. but it is making the engine work harder and hotter.. which will reduce the life of it and all the drivetrain parts.
