Fuel Tank Q
Old 05-08-2005, 07:06 AM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
How many littres/gallons can be filled in fuel tank?
When should Empty Fuel Tank Lamp turn on?
I filled full tank, used about 13.4 gallons and that lamp didn't turn on.
How to check it? Any body have/had this problem?
Old 05-08-2005, 07:12 AM
brian01tib's Avatar
14.5 gallons is the size of the tank
Old 05-08-2005, 09:04 AM
CyberShark's Avatar
The empty fuel tank light comes on when you have a gallon or less of fuel in your tank. It's done that to me a couple of times.
Old 05-08-2005, 09:45 AM
Dmitry's Avatar
is there any way to check it?
1 gallon is very small, you can go on it only about 25-30 miles.
I thought there should be 2 or more gallons for light to be on.
Old 05-08-2005, 10:04 AM
yes, the gas tank on the Tib is 14.5 standard gallons and 12.1 imperial. My personal findings are, I have put 14.5 gallons in my tank when I have run it extreamly dry (to where the car would not accelerate due to fuel starvation) but I also always get over 30mpg. Last weekend I drove almost 900 miles up to Boston, then almost New Hampshire.. then back down to Atlantic City. Staying at a constant 70mph, I got just under 34 miles to the gallon on both tanks. And yes, I only filled the car up twice. Once before I left and once before I came back. 450 miles for both fill ups.
Old 05-10-2005, 02:07 PM
TiburonWao's Avatar
AS soon as my "Low Fuel" light turns on, I fill my tank at the top.... It can take 15.8 gallons.... weird.... but true... that cost me $40 bucks...
Old 05-10-2005, 02:20 PM
spiceflow's Avatar
I have found that if I fill up right when my fuel light starts coming on, the car will take 12.5 US gallons. So, about 2 gallons left i the tank.
Old 05-10-2005, 02:53 PM
Tibminn's Avatar
ok hmmmm.... either my gas gauge is phucked up or i have a way smaller tank than you guys....
lowest i ever ran the tank down filled back up with a little over 10 gal... and that was WAY low. i has just assumed it was like a 10-11 gallon tank and my gas light was broken... but it sounds more like my gauge is broken. Im definately gunna have to look into that...
Old 05-10-2005, 03:47 PM
generally I have found that I am on empty for a while before the light comes on.
Old 05-10-2005, 04:21 PM
Zman's Avatar
<div class='quotetop'>QUOTE (TiburonWao @ May 10 2005, 08:07 PM)</div><div class='quotemain'>AS soon as my "Low Fuel" light turns on, I fill my tank at the top.... It can take 15.8 gallons.... weird.... but true... that cost me $40 bucks...
LUCKY YOU!!! To fill up my gas tank (usually 13,5-14 gallons) cost me $60 bucks!!!
<div class='quotetop'>QUOTE (TibMinn @ May 10 2005, 08:53 PM)</div><div class='quotemain'>ok hmmmm.... either my gas gauge is phucked up or i have a way smaller tank than you guys....
NO way there are Tibs with different size tanks. Your light must be regulated to light on earlier than most of us, that's all.
