Fuel Pump Help
Old 06-24-2005, 10:59 AM
  #21
UltraTibby's Avatar
I am really not sure they mean by the connector. I couldnt find a good pic of it on WebTech. It seems that on the firewall there is a connector that would allow you to give power to the pump without having the car on. Like Jon said the best way to check it is by using a gauge somewhere between the fuel filter and the FPR. The pressures are on WebTech. They actually give you two pressures. One for without the FPR connect to the IM and one with it connected.
What are the problems you are having with the car?
Old 06-24-2005, 11:30 AM
  #22
Okay, few questions.
1. How many miles on the car?
2. What mods? Most recent mod?
3. When is the last time you changed or looked at your plugs & wires?
4. Ever run a good fuel injector cleaner thru it?
5. Ever change your fuel filter?
Old 06-24-2005, 06:56 PM
  #23
AllEyesOnME's Avatar
1. about 90,000
2. obx headers, 2 1/4 piping no cat, new sparks new wires, cold air
3. last year
4. yes last fall when my problems started
5. yes last fall.
Old 06-24-2005, 07:02 PM
  #24
UltraTibby's Avatar
Ok, so what problems are you having? Also, do you have a cel because of the cat?
Old 06-24-2005, 07:08 PM
  #25
Which CAI do you have? Got pics?
Old 06-24-2005, 07:12 PM
  #26
[its a custom made one,
my problem is when you drive the car for a awhile then turn it off and let it sit for an hour then start it again, it take a while to crank over.
Old 06-24-2005, 07:16 PM
  #27
I remember you posting about this.
Last time I saw this almost IDENTICAL problem, it was the TPS. Just needed a new one.
Old 06-24-2005, 07:17 PM
  #28
UltraTibby's Avatar
Just for example mine takes a few cranks to turn over when I do that same thing. Drive a bunch, let it sit for an hour, then drive it again. Now I dont mean like 30 seconds or anything but it does take longer to turn over then rather than when its only off for say 15-30 minutes or so.
Old 06-24-2005, 07:24 PM
  #29
the TPS was changed also was 1 o2 sensors
there are no CELs
and when it been sitting all nite it starts fine. only when you drive then let it sit for a bit it has a problem
Old 06-24-2005, 07:27 PM
  #30
Have you had the ECU scanned anyways? Sometimes it'll show stuff that's not a MAJOR problem, but that you may wanna look at.
So, after driving it for some time it has difficulty starting right?
Have you taken a look at your TB and the vaccum hoses? Maybe you have a leak or one that's plugged up.
