Fuel Line
Vehicle: 1991 Nissan 300zx
I need some help here, when i was replacing my fuel filter i broke the fuel line that goes into the fuel filter, and i was wondering if anybody has a part number or a diagram of all the fuel lines so i can order one. thanks in advance
Did you look at the DIY section? There is a quick refrence parts listing in there.
I just looked and theres nothing in there, i couldnt find anything on webtech either? here are some pictures of what happened.
i need to get this fixed as soon as possible since the tib is my daily driver, all help is aprecitted thanks again for looking
Did you look on the Hyundai Parts website?
http://dcs.hyundaidealer.com/customer/index.jsp
31320-29110
I think that's the part # for the upper line, or...
31310-27100, for the lower line.
Anyways, it was pretty easy to find. Login on the parts page, go to the parts section, click on the parts search, click on Passenger when it comes up and 97MY Tiburon.
Then click on Engine, go to Fuel Lines, and whammo.
31320-29110
Get 1 foot of fuel hose, a barb fitting, and 2 hose clamps. Costs less than $5.
Slide the hose over the metal fuel line, then clamp it down. Screw the barb fitting into the fuel filter, then slide the hose over the barb and clamp it down with a hose clamp.
Just a cheap way to do it since they'll probably charge you like $100 for the OEM line that runs to the back of the car.
get a flaring tool, re-use your old fitting and redo the flare.. no need to change the whole fuel line or use rubber
