Fuel Injector Question
#22
Tim cut the pig tails off his old motor he had laying around and then i just spliced them into the harness and called it good. *in fact first time we started the engine one of em wasnt fireing cuz my splicing job sucked and Tim had to fix it*
#23
Is there like a set way of doing this or am I going to end up jerry rigging this lol? Like is there a process like I get accell 340cc injectors, grind this much away from the fuel rail, buy these spacers from this place, buy these pigtails and hook them on, use these spacers, etc? Sorry for all the questions there is just a few things I am confused about before I go with the injectors... Thanks
#24
there is no way to do it with your stock injector plugs (aka pig tails)
there is no way to do it without cutting your fuel rail
if either of the above = jerry rig in your eyes, then YES you have to jerry rig it.
Tim has the specs on the spacers
#25
Guest
Posts: n/a
But yes I do have all the specs for the Spacers and Bolts needed and the Fuel Rail mod is a simple task aswell.
But as rich stated there is no way to use the pigtails for the stockers you will have to get new clips for the 340cc.
#26
<div class='quotetop'>QUOTE (azwildfire)</div><div class='quotemain'>there is no way to do it with your stock injector plugs (aka pig tails)
Tim has the specs on the spacers</div>
Doode, everyone is welcome here, but you need to understand, this site is for RD Tiburons, we ALL have Beta 1's.
