Figuring out Ignition Timing
Vehicle: 2000 Tib
I have a question, I'm trying to find out where exactly my ignition timing is at with my car. I already have a wideband/egt temp gauge however thats not enough to me. Is there a way to figure out the spark timing of my motor while on the dyno? Would I use a timing light? Or is there a scanner I can plug in?
Thanks
Thanks
If i remember correctly you can read your timing through the OBDII port. any scanner that can read live sensor data should be able to see it. i think there is also a way to use a timing light on these motors but i've never bothered to check because it's not adjustable from the factory.
