Electrical Short
I will change th eharness today today to see what happens
What i also was trying to say is that i have constant power on both PINS of the harness while the car is OFF.I dont think thats normal or there should be constant power coming out from the plug !!
well, the other wire is most likely going to receive power from the one its running right next to if you have power on both.
follow the headlight wires back and look for cut or crushed sections.
Funny thing is i diconnected the bulb plug on the passenger side and when i check for power i have only one with power.I also pulled out both High and low beam fuses from the box and still HAVE constant power coming from the car WTF? mad.gif
I also tested the plug which goes into the light houseing and there is power on all terminals..
You guys think it can be my Day time running module box?
Its installed on the driver side fender
Thanks!
Thanks!
