Egine Is Loudddd
My engine at idle AND accelerating is getting louder and louder daily. my only aftermarket part is an aem knockoff cai...
any idea to why it is getting so loud under the hood? also... my car seems much less responsive than it was in the past. I can not figure out what the deal is.
thanks
thanks
loose or cracked exhaust manifold. look to see if you have had the factory recall done on the exhaust manifold. another place to look is see if you have a leak in your exhaust system, specifically around the flex pipe as sometimes they are very hard to see if the leak is under then mesh.
they will crack right along the flange of the manifold. if it's loose, 14mm socket does the trick on that one. i dont remember the exact torque specs but i usually just hand tighten them with a 3/8" socket wrench until i can get them any tighter. I'm not a body builder by any means so i am not worried about breaking off a stud in the head.
Also look for cracks where the runners meet. The pipes that come off the side of the engine, where they join together, is a crack-prone area.
Verify the security of the intake pipes also. Tighten it all even if it looks tight, you might be surprised.
well my car got broken into so its at the shop now getting fixed... i get it in an hour so i will look around for these cracks.. not really sure where to look but i should find it
