double clutching
Old 12-15-2004, 10:01 PM
2bits's Avatar
Default Re: Removing dashboard
Supposidly it is better for your engine, but i am wondering if anyone can acccually do it fast enough to race with it. I mean i have been doing it for about a week now for fun, just seeing if i can get good at it, i am getting better but not nearly as quick as just shifting.
Anyone that races double clutch or no??
2bits is offline
Old 12-15-2004, 10:18 PM
purpletib's Avatar
Vehicle: 2000/Hyundai/Tiburon
Default Re: CheeseBurger Anyone?
I'm a total noob when it comes to driving a stick. I don't even know how to double clutch oops.gif :roll: Only been driving a stick for a couple of months now. From what I've been told it doesn't really help in racing, just downshifting. F&F is full of crap.
purpletib is offline
Old 12-15-2004, 10:27 PM
Double_A's Avatar
Default Re: double clutching
I guess i should know this by now considering I have only ever driven stick, but i must say im not even sure how to do it. I know this is a noob question but since were on the topic, could you explain it to me. Thanks
Double_A is offline
Old 12-15-2004, 10:53 PM
2bits's Avatar
Default Re: Pics of my car in Chile
well from my limited experiance with it......
When u shift from lets say first to second, u put it in neutral, let the clutch out, then put it in second...
as for downshifting, u can down shift without double clutching, i am doing it currently for fun. I am not even sure if i am doing it correctly and if it is even worth my time. it is a bit of a challenge if ur bord of everyday driving...
2bits is offline
Old 12-15-2004, 11:00 PM
tanc's Avatar
Vehicle: 1997 Tiburon
how does it go in second with the clutch out?
tanc is offline
Old 12-15-2004, 11:06 PM
Torteth's Avatar
Google is your friend:
http://www.answerbag.com/q_view.php/4101
Anyway, Double Clutching is Effort++ and so isnt the thing for me... wink1.gif
Torteth is offline
Old 12-15-2004, 11:07 PM
col96fx's Avatar
Vehicle: Hyosung GT650
Obviously you put the clutch back it to put it in gear.
This is how it goes
Changing up
1. Clutch in
2. Change to neutral
3. Clutch out
4. Clutch in
5. Change into gear
Changing down
1. Clutch in
3. Clutch out & rev engine (a quick squirt of the trottle)
4. Clutch in
5. Change into gear
col96fx is offline
Old 12-15-2004, 11:08 PM
2bits's Avatar
yeah sorry, i thought the putting the clutch back in part was obvious, my mistake...laugh.gif
What about the advantages/disadvantages of it....
*Edit*
I read the link above, makes sense I guess it helps but not worth it when raceing
2bits is offline
Old 12-16-2004, 12:16 AM
Torteth's Avatar
Default Engine Splutters.. need help... chain of problems
I think the misconception that it helps you in races stems from the start of the Fast & The Furious.
Havent seen it (or the second one for that matter) so I could be wrong.
Torteth is offline
Old 12-16-2004, 12:19 AM
evan938's Avatar
from what ive learned, this is something that needed to be done w/ older cars that had something to do with getting the syncros lined up correctly...with new cars, its not needed...
i wish i remember where i saw the post so i coudl show you all
evan938 is offline
