Cruise Control Won't Work? FIX FINALLY FOUND!
Old 07-24-2004, 11:28 AM
  #21
Default Re: Southern Chapter
its only the stop lamps. i checked out the schematic at webtech, and the stop lamps are the only things on the circuit.
01tibby is offline
Old 07-26-2004, 08:05 AM
  #22
tibwrcsbj's Avatar
Default Re: A little more progress *MORE PICS ADDED*
cool thx tibby.....Redz I will install them some time this week....going to be a bia for me to get pics tho....
I will have to park my car near an outlet, since my digicam refuses to work on batteries.....but works just fine when plugged in.
tibwrcsbj is offline
Old 07-26-2004, 11:39 AM
  #23
Default Re: lambo door GB
Don't worry about pics mang, I can figure it out.
REDZMAN is offline
Old 07-26-2004, 03:34 PM
  #24
tibwrcsbj's Avatar
Default Re: *POSSIBLE* Lambo Door GB
cool ^^
Im looking at one right now, all it is is two wires coming out of what looks like a little metal heatsink (wire taps included)
so basically tap the power and ground wires and find a place to screw the metal part on. thats it.
Old 07-26-2004, 06:02 PM
  #25
Default Re: NOPI St. Louis - THIS WEEKEND
<div class='quotetop'>QUOTE (REDZMAN)</div><div class='quotemain'><div class='quotetop'>QUOTE (tibwrcsbj)</div><div class='quotemain'>Be more specific REDZ.....the bullets or the resistors??? ;-)</div>
I was thinkin about that too, I know they flash like that for that reason, I turned on my blinkers when one of my corner bulbs was out and it was fast as hell. Coolio. I've got no problems with them blinkin fast, I just want my shiz to all WORK.</div>
Some places... Like NJ.. will fail you if your blinkers work too fast
Mad-Machine is offline
Old 07-26-2004, 08:05 PM
  #26
TibRacer01's Avatar
Default Re: 1000hp RD2
TibRacer01 is offline
Old 12-11-2005, 04:17 PM
  #27
you know how incandescants can be lined up in series and just keep getting dimmer and dimmer, and LEDs go dimmer and then off?
an LED will drop it's FWD bias in voltage. LEDs work funny because of their foreward bias. An LED takes a certain ammount of voltage to power its P/N junction and everything else is passed through it. You will get voltage applied minus about 2V out the other end of the LED.
aside from the voltage dropped for foreward biasing the LED works the same as an incandescant.
DTN is offline
Old 12-12-2005, 12:49 AM
  #28
Okay, the last post in this thread was over a year ago. Hell, a year and a HALF AGO.
What does your post have to do with that or anything else in this thread? Cut it out man.
REDZMAN is offline
Old 12-12-2005, 05:01 AM
  #29
Didn't realize the thread was that old. that's probly the reason that the LEDs won't work in the tail lights though mang. something is supplied power through the tail lights and it's not able to get that with LEDs because of the FWD bias voltage dropped by the LED
DTN is offline
Old 12-12-2005, 09:03 AM
  #30
We know why it won't work. They have too little voltage draw. This is why this thread was started. Please pay attention to at least the YEAR a thread was last posted in.
Stop posting in here unless you have a new issue with this or have other data folks.
REDZMAN is offline
