Compression Test
Old 04-19-2005, 12:35 PM
well i rechecked
results as followed
1. 188
2. 192
3. 182(about)
4. 186
im alright with this test i added oil and it moved up to about 196-200 each one or so again this is with the fuel pump still spraying (i didnt know how to disconnect it)
again i have 138k on this engine so i feel like its wearing pretty good
Old 04-19-2005, 01:53 PM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
Not bad for so many miles.
To disconect fuel pump - simply take out pump fuse.
Old 04-20-2005, 08:17 AM
Mad_john's Avatar
i think i will do one,btw where is the fuel pump fuse?
Old 04-20-2005, 01:08 PM
hamhead's Avatar
Box thingey in your engine bay... least I would imagine it would be there. Which fuse it is I have no idea. Webtech is your friend, go look there.
Old 04-20-2005, 01:24 PM
Dmitry's Avatar
I didn't find a fuse for fuel pump, but I found a relay for fuel pump (it's under the hood). On the box there should be a mark - withch relay is for what.
Old 07-19-2006, 04:47 PM
01steve's Avatar
Vehicle: 2000 hyundai tiburon
where is this fuel pump fuse/relay? it's not listed too well on the cover. "b+" for example so if you could tell me what it is right next to or what it's labeled, it'd be great! also are you able to do a word search on webtech anymore?
Old 07-19-2006, 05:09 PM
bumpintibby's Avatar
don't worry about the fuel pump fuse, just disconnect the injectors
Old 07-20-2006, 02:28 AM
Dmitry's Avatar
disconnect harness under rear seat
Old 07-20-2006, 06:31 AM
You dont want to disconnect the fuel pump. If you do that, the injectors will still fire without any fuel goin thru them to cool them down.
Old 07-20-2006, 09:45 AM
LarryMcFly's Avatar
Compression test is a good sign of engine wear, you can also do a leak test. Adding oil will make a better compression test but won't improve the leak test. Also, if you have agressive cams, you will get lower compression figures.
