Cold Air Intake Heat Resistance
Old 01-31-2005, 10:33 PM
OdessitPashka's Avatar
<div class='quotetop'>QUOTE (hamhead)</div><div class='quotemain'>Gah, its some sort of spray I saw it somewhere. I knew ceramic coating involved charging the surface so I couldn't see how it would've worked. I think someone sprayed their downpipe with it because the heat from it was messing with the alternator... I'll find it somewhere...
While I realize that wrapping a header with heat wrap that gets 1600degrees and wrapping an intake that might get 200degrees will mean probably less corrosion if any because of the wrap, I personally don't trust the wrap. I've seen holes cooked in headers cause of that stuff.</div>
but we are not talking about 1600F here, intake wraps will do just fine. Look through those pages that I sent you smile.gif
There is also special spray for downpipes smile.gif just check that page out man!
Old 01-31-2005, 11:28 PM
a_gut's Avatar
Heat wrap doesn't keep heat in necessarily, it keeps two bodies of different temperatures from affecting one another. So, if you wrap headers, they'll get hotter because heat from the pipes isn't being released into the air in the engine bay. If you wrap your intake, it won't soak in as much heat from the engine bay, and thus stay colder.
Old 02-02-2005, 01:38 PM
Slipstream's Avatar
the spray stuff dosent work that well. find someone in your area that dose true powder coats or send it to jet-hot.com and have them do it.
you can do it your self but it can get messy and you'll need an oven to bake it with.
Old 02-02-2005, 02:29 PM
Here is an effective air intake wrap.
http://www.eastwoodco.com/shopping/product...1&keyword=70308
Old 02-02-2005, 04:41 PM
MechaniX_034's Avatar
Vehicle: Lancer Evo IX
Yup, the DEI one Redzman posted is good. I'll be making my own from heat shroud of similar material[perhaps a mil or so thicker]
Old 02-02-2005, 05:24 PM
CyberShark's Avatar
I'd go with the one that Redz posted..heat wrap works good but it will start to come off after awhile...
Old 02-02-2005, 10:12 PM
Anyone know where DEI's site is?
Old 02-02-2005, 11:00 PM
<div class='quotetop'>QUOTE (REDZMAN)</div><div class='quotemain'>Anyone know where DEI's site is?</div>
Never seen their website, but I know you can get their stuff through summitracing.com, relatively cheap too.
Old 02-05-2005, 07:09 AM
TiburonWao's Avatar
Nice air intake wrap.,.... I vote for this one
Old 02-05-2005, 07:52 AM
CyberShark's Avatar
Jegs sells a similar wrap (if not the same thing) costs around $40 to $50 if I remember correctly..even has different colored "shoe laces" to match engine color
