Cold Air Intake Heat Resistance
Old 01-31-2005, 09:56 PM
MasterJ51503's Avatar
Default Cold Air Intake Heat Resistance
AEM uses a protective spray... or coating of some sort on their CAI's to prevent the intake from obsorbing engine heat... is it possible to buy this at a store such as advanced auto? ive been searching around... but i cant find the name of it.
Old 01-31-2005, 09:59 PM
hamhead's Avatar
Called powdercoating. You can't buy it in a can. I think they make ceramic coating in a can, but its no where near the effectiveness of the actual ceramic coating process.
Old 01-31-2005, 10:03 PM
OdessitPashka's Avatar
<div class='quotetop'>QUOTE (hamhead)</div><div class='quotemain'>Called powdercoating. You can't buy it in a can. I think they make ceramic coating in a can, but its no where near the effectiveness of the actual ceramic coating process.</div>
Old 01-31-2005, 10:10 PM
hamhead's Avatar
I wouldn't resort to using reflective adhesive tape... either way, its no way tape would equal the effectiveness of powdercoating. If your going to do that, you might as well get a firefighter's outfit and wrap it around your intake. tongue.gif
Old 01-31-2005, 10:12 PM
<div class='quotetop'>QUOTE (hamhead)</div><div class='quotemain'>I wouldn't resort to using reflective adhesive tape... either way, its no way tape would equal the effectiveness of powdercoating. If your going to do that, you might as well get a firefighter's outfit and wrap it around your intake. tongue.gif</div>
they sell that too smile.gif not quiet a firefighter outfit, but you can buy special material and put it on your pipes to prevent any heat getting to your pipes smile.gif
Old 01-31-2005, 10:18 PM
hamhead's Avatar
You talking heat wrap? Heat wrap is the devil, very damaging. Hoping the tape doesn't do the same thing as that blasted stuff.
Old 01-31-2005, 10:20 PM
MAXXTIB's Avatar
Most wraps will out perform "powdercoating" as far as reflecting heat goes.And heat wrap will not damage an intake since there is no major heat source there.
Old 01-31-2005, 10:21 PM
Arctic Seraph's Avatar
Nope. I don't see how ceramic coating would be in a can...b/c it's a similar process to powder coating, where the metal surface becomes charged and the ceramic particles cling to the surface and they bake the finish.
Old 01-31-2005, 10:23 PM
http://store.summitracing.com/default.asp?...h&Ntt=heat+wrap
here
Old 01-31-2005, 10:31 PM
hamhead's Avatar
Gah, its some sort of spray I saw it somewhere. I knew ceramic coating involved charging the surface so I couldn't see how it would've worked. I think someone sprayed their downpipe with it because the heat from it was messing with the alternator... I'll find it somewhere...
While I realize that wrapping a header with heat wrap that gets 1600degrees and wrapping an intake that might get 200degrees will mean probably less corrosion if any because of the wrap, I personally don't trust the wrap. I've seen holes cooked in headers cause of that stuff.
