Ckp Sensor
Do you mean online? Try Hyundai Parts Online. Look in the OEM Catalog under Mechanical Catalog>Electrical>Powertrain Control>Crankshaft Position Sensor.
ok got a new ckp sensor went to change them out when doing it I got the sensor out and the bolt off but on the male to female plug side where the 2 connect, I can not get it off. There is a little metal wire running around the actual female side does that metal wire have to be taken off somehow to get the male end out?
Edit: Sensor has been removed you DO have to move wire around female end to get the ckp sensor out. Once I removed the sensor I looked in the female side and I noticed there is some type of blue colored looks like lotion in there any ideas? Not like alot but I bet it would make the sensor not work.
lol ^^ thx. I also looked the lotion stuff up online, the blue compound lotion looking stuff, is a type of electrolisis lotion to prevent water coming through into the sensor.
