Cel P0138 & P0141
Old 04-07-2010, 09:44 PM
Fun fact: if your fueling was way off because of the bad O2 sensor, it could have killed your brand-new catalytic converter. 02.gif
Old 04-07-2010, 11:09 PM
dddude55's Avatar
Vehicle: 2011 Kawasaki ZX6R
High flow cat may not remove enough of the bad stuff to make the secondary o2 sensor happy.
Old 04-07-2010, 11:15 PM
radu_rd2's Avatar
Vehicle: 2006 Pontiac GTO
<div class='quotetop'>QUOTE (streettibb28 @ Apr 7 2010, 08:26 AM) <{POST_SNAPBACK}></div><div class='quotemain'>I know its not my cat its brand new Magnaflow high flow cat.</div>
It's probably your cat. Most of the people here have always had a hard time finding aftermarket cats that are good enough to not trip up that code (yes, even magnaflows).
I have a magnaflow that barely works (it tripped up the code once or twice but once I cleared it was ok for a long while).
You can use a spark plug non-fouler to install the secondary O2 slightly outside of the stream and trick the ECU this way, DTN did this on his.
Old 04-12-2010, 07:09 AM
streettibb28's Avatar
Vehicle: 1998/Hyundai/Tiburon
Thanks everyone for the help. I did the spark plug non-fouler and i am keeping my fingers crossed lol. I will come back with results haha.
cheers.
Old 04-12-2010, 07:53 AM
David Dickson's Avatar
Never use cheapo Magnaflow cats. They SUCK! Get a high quality one from Random Technology Cat and you'll never had that problem again.
Old 04-15-2010, 06:40 AM
^^ Will keep note of that prob over the summer i will replace it with the one you mentioned thank you.
Okay good news I got no codes and I passed emissions so it worked =). Thanks again for everyones help.
cheers
