Car shudders when I lift up on the clutch
U obviously have a transaxle issue, sensor issue, maybe a clogged fuel filter, sounds like its starved for fuel and cannot stay idle and stable for too long
but like, in all honesty, that could be cause of anything
or u cant shift and think your car is something else maybe??
![Shifty](https://www.hyundaiaftermarket.org/forum/images/smilies/Shifty.gif)
I did some reading up and it looks like PL Polyurethane is the way to go. It cures much faster than window weld and has a little more give than window weld (which should cut down a bit on vibrations). It's also only $5 a tube at Lowes, 1/4 the price. So I'm going to be doing that this weekend. Let you know how it works out!
Also, is there a little check hole or something to look in and check on the clutch padding and flywheel? I remember my old Acura had something like that, but I don't see a cover anywhere on this transmission.
