Car Overheating
Old 06-14-2009, 10:17 AM
  #31
Bommello's Avatar
Might want to give this a try, if it's not a flow problem.
http://www.rdtiburon.com/index.php?showtop...&hl=coolant
Old 06-14-2009, 10:30 AM
  #32
radu_rd2's Avatar
Vehicle: 2006 Pontiac GTO
I thought about trying that, but it requires to somehow drain ALL the old stuff from the engine block, which I just don't have the equipment to do..
Old 06-14-2009, 01:11 PM
  #33
Hive's Avatar
<div class='quotetop'>QUOTE (Stocker @ Jun 14 2009, 03:57 PM) <{POST_SNAPBACK}></div><div class='quotemain'>It's easy enough to find a fan company making a fan/thermostatic switch bundle so you don't have to remember/notice to switch on.</div>
I have a fan/thermostatic switch bundle from FAL but never do get around it to install. Maybe I will these comming days.
Also thing is that it does not overheat when cruising but only when driving around in the city and stopping at traffic lights. As soon as I do not get enough air flow thorugh the bumpew I have to run both of the FAL's to keep it at normal temperature.
Old 06-14-2009, 01:53 PM
  #34
javageek's Avatar
Probably the only other differences I can think of are I have a VIS hood and Cuda 2 bumper. Maybe I have better air circulation because of that.
Old 06-14-2009, 01:55 PM
  #35
radu_rd2's Avatar
^And also I think your rad is a bit closer to the middle than mine.
My fan might not be all that strong either, I can't wait to add the 10" pusher fan in front of it and see what happens. I really wish I could modify the ECU to start them earlier, at like 185F instead of 205F haha
Old 06-14-2009, 02:10 PM
  #36
If you have a huge gaping hole for air to go into the engine bay then you don't have a proper shroud. Put a piece of cardboard in the opening, just to give a bit of resistance to the air and encourage it to go thru the radiator. $0 and easy. Then make a good one out of sheet aluminum or something if that helped.
  #37
javageek's Avatar
^^ There is another difference I have the Haltech kicking the fan on at 185.
Old 06-14-2009, 02:12 PM
  #38
all i know is this making me question installing my 2 slim line fans
Old 06-14-2009, 04:12 PM
  #39
hamhead's Avatar
Well, you could always jump the circuit and wire your fans so they stay on all the time. laugh.gif
Old 06-14-2009, 04:16 PM
  #40
radu_rd2's Avatar
^ Ya i could have the pusher fan on all the time, and the puller fan wired into the stock circuit. But even that I'm not sure how to do easily, I don't want to route any more wires between engine bay and cabin haha
Is there some wire that I can tap, perhaps just for some small current to open a relay?
