Car Is Leaking
<div class='quotetop'>QUOTE (Dmitry @ Sep 20 2005, 06:09 PM)</div><div class='quotemain'>^^^
be carefull it can be a dog's urine...
LMFAO!!!
yeah, just taste it. if it is water, you have nothing to worry about. its just dripping from somewhere.
LMFAO!!!
Are their any fluids low? if so then this may be the source of the leak.. Otherwize it sounds, by the description, that it is just water from the A/C evaporator. The A/C on a lot of cars comes on when you have the HVAC mode controles set on defrost, so the A/C could be on and you not know it. You may want to clean out the A/C drain ( with compressed air blowing straight up into the drain tube) to clear any debris out so that it drains faster and you won't have such a big puddle accumulateing over time. That is if this is the issue.. Good Luck! fingersx.gif
Vehicle: tiburon 1998
Aother option, if it rained ON he car, is that the water coming into the area in front of the windshild is routed downsteirs using a couple of tubes, hided under the fenders.
