Car has no sparkie
Old 12-05-2004, 03:43 PM
Dweet's Avatar
Default Re: some questions... bought some new stuff
My car has no spark. I tried switching coil packs and no fuses are blown... so whats up?
Old 12-05-2004, 03:45 PM
OdessitPashka's Avatar
Default Re: Is there a larger MAS?
did you do anything with ignition before?
how did you check that you don't have a spark?
Old 12-05-2004, 03:56 PM
Dweet's Avatar
pulled a plug and sat it next to a ground and tried to start the car..
Old 12-05-2004, 03:59 PM
Default Re: cuda kit
you never messed with ignition, did you? no MSD or anything?
check all of the connections, fuses, battery.
Old 12-05-2004, 04:08 PM
Dweet's Avatar
Default Re: Car has no sparkie
no MSD, all of the above are good
tried swapping wires and the transistor as well
Old 12-05-2004, 04:16 PM
Default Re: aftermarket parts and stock parts added a couple things
Did you have SAFC installed? if so, check all the connections on your ecu after ununstalling it.
if that doesn't help then wait till more experienced people reply.
Old 12-05-2004, 04:18 PM
a_gut's Avatar
Check your camshaft position sensor.
Old 12-05-2004, 04:48 PM
Dweet's Avatar
Default suspension noise
ok the car runs now.. but once it gets above 2k RPM it bucks, and pretty much dies till the RPM's go low and then it comes to life again :?:
Old 12-05-2004, 05:27 PM
Default Re: FS: Stock Corners, Taillights, and Head Unit
check all the sensors. that acceleration sensor will fock things up. make sure there arent any leakes past the MAF.
maybe you need some new wires or plugs.
any CEL? how did ya fix the spark problem, or is the car just running on 3 cylinders?
Old 12-06-2004, 10:23 AM
Dweet's Avatar
Default Re: FS: My turbo stuff
its running fine.. just the usual CEL im not going to post why it ran like crap once i got it running because then id sound retarded smile.gif
